ecm does not accept programming
Old Sep 12, 2008 | 10:35 PM
lejj909's Avatar
lejj909
Default ecm does not accept programming
contact your HD dealer that was the error message i recieved when i try to download a map from sert i was nervous of hearing that i need to change the ecm anyone can flush the ecm? need a lot of help here please
Old Sep 12, 2008 | 11:10 PM
scotty3's Avatar
scotty3
What version of the sert and what map
Old Sep 12, 2008 | 11:24 PM
lejj909's Avatar
lejj909
sert 476
map 67
176ae104.a1
Old Sep 13, 2008 | 01:03 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Have you check to see if the bike still runs?
Old Sep 13, 2008 | 02:05 PM
oldfartjc's Avatar
oldfartjc
Is this the first time you've used your SERT? Are you using a serial port adapter on a newer laptop that doesn't have an actual serial port, and also are you running Vista? Only certain adapters work properly like the Belkin, and I've heard that Vista can cause some problems.
Old Sep 13, 2008 | 02:08 PM
lejj909's Avatar
lejj909
yes the bike still runs from the old map
Old Sep 13, 2008 | 02:16 PM
lejj909's Avatar
lejj909
no i've used it a lot of times trying different map the pentium 133mhz laptop gave up and die so i have to use another laptop unfortunately running vista and theres no serial port so i used usb first attemp the bootloader didn't load up says the error second attemp error says your ecm does not accept programming access denied contact HD dealer
Old Sep 13, 2008 | 02:27 PM
Wecroft's Avatar
Wecroft
Get a Belkin USB to Serial adapter, I guarantee it'll work. I got the same "Bootloader" message when I tried another brand.
Old Sep 13, 2008 | 02:48 PM
ViennaHog's Avatar
ViennaHog
the older sert does not reliably work with vista, look for an xp pc with serial connector to reduce trouble. Find the final release of the sert software 4.77, some maps are reworked
Old Sep 13, 2008 | 03:24 PM
oldfartjc's Avatar
oldfartjc
Hey "lejj909", below is a link to download SERT Version 4.77 which is the latest version.
http://www.sendspace.com/file/q7d973
vinnieee
13
Oct 11, 2018 11:48 PM
Jezcruzen
May 20, 2007 06:53 PM
07 Fatboy
Apr 27, 2007 01:52 AM
Jim Dawson
Jan 19, 2007 02:26 PM
clayman
Jul 23, 2006 01:07 AM
