'87 flhtc radio problems
To enter the radio diagnostic mode, press any two (2) station preset buttons simultaneously while turning ignition on. There are five (5) diagnostic modes (D1-D5) plus Automatic Volume Control (AVC) setting. Digits will change from 0 to 1 when function button is operated. If digit does not change, there is either a short or open on that circuit (see Service Manual or ED for codes). To cycle through the various diagnostics, use the LO/DX button.
D1: Switch Function Mode will display a five (5) digit binary code at the top of the LCD.
Digit 1=Mode set, up & down
Digit 2=FPTT, RPTT, Volume up & down
Digit 3=Audio in, Squelch-, Eject
Digit 4=Audio-, Squelch+
Digit5=Audio+
D2: LCD displays an 8-digit code
Digit 1=PTT microphone Digit 2=Vehicle speed Digit 3=VOX break Digit 4=CB SQ break Digit 5=IC on/off Digit 6=CB on/off Digit 7=SPKR SW B Digit 8=SPKR SW A
D3: LCD function=Illuminates all display items in radio LCD.
D4: Model year=Select model year as prompted.
D5: Software=Displays software information
AVC: Automatic Volume Control=Adjusts volume to engine speed. 0 to 4 range with 2 the factory setting and 4 being the most aggressive setting.
If this is not applicable and if everything is working (power to radio/tape plays), I would look for the main speaker wire having an open from the radio back.
