leaning out a rich running 1996 Fatboy
Old Apr 6, 2006 | 10:08 AM
Sturgisdude's Avatar
Sturgisdude
Stage IV
Default leaning out a rich running 1996 Fatboy
I am trying to change all the things I can change to make my bike run leaner. I am putting the #160 main jet in the stock cv carb, using the hottest plugs I can find, install the least restrictive air cleaner, and if it would make any difference I would consider removing the baffles from the pipes that are on there. I have a Dyna 2000i ignition setup (with coil) and SE 8 mm plug wires. Can anyone suggest anything else that would accomplish this. The engine is stock. Thanks for any suggestions. Sturgisdude
Old May 8, 2006 | 03:29 AM
harley387's Avatar
harley387
2nd Gear
Default RE: leaning out a rich running 1996 Fatboy
Why would you do this????? Is there a problem with the bike? If not, then by leaning it out, you WILL have.
Road Star
Sep 17, 2014 08:34 PM
fatboycustom3311
EVO
Aug 20, 2014 04:18 PM
Batch05
Jul 11, 2013 09:23 AM
daverso
Dec 2, 2010 06:16 PM
FatBoy94
Oct 16, 2007 02:40 PM
