Carburetor Tuning - Help!!!
Old Jul 8, 2013 | 09:30 PM
Batch05's Avatar
Batch05
Default Carburetor Tuning - Help!!!
I have a 2001 Fatboy and just installed some new Python sideshot slipons. I originally had the stock pipes with the baffles punched out. I was told that a correctly tuned carburetor would result in spark plugs being a "poopy" brown color. I have attached a picture of my spark plugs after changing out the pilot jet only to one size bigger. So far I have discovered that doing nothing gives me a lean mixture. Changing out main jet and/or pilot jet individually seems to give me a too rich mixture. Any suggestions? Looking at the spark plugs, am I even close? Help!!!!!
Old Jul 8, 2013 | 09:34 PM
hyde802's Avatar
hyde802
Old Jul 8, 2013 | 10:12 PM
the blob's Avatar
the blob
They dont look too bad. looks lije too much choke
Actually. Id fatten it up using the mix screw. If it carb farts
You know its lean.
Old Jul 9, 2013 | 12:34 PM
rideflhr's Avatar
rideflhr
I would put a #48 pilot jet and a sportster needle. Be sure to take out the adjusting plug so you can get it right.
Old Jul 10, 2013 | 09:22 PM
gators's Avatar
gators
6th Gear
+1 on the #48...then just tune with the air/fuel screw. If its too lean you'll def know...fart fart
Old Jul 11, 2013 | 09:23 AM
roadkingharry's Avatar
roadkingharry
If you want to tune a carb by "reading" your plugs, you have to do a plug chop. Google it or use Youtube if you don't know what that is. Contrary to what others have said, on a stock engine regardless of what exhaust you have, 45 is the biggest you want to go on the pilot, 185 on the main. Then adjust the a/f mix screw to get to the optimal tune. You can get a real good tune by using the seat-of-the-pants dyno while you evaluate any hesitation or carb farts and making adjustments to the a/f screw. If you want to get more technical than that, go see a tuner who has a sniffer that gets inserted into the exhaust to check your exact air to fuel mix through the RPM range.
Csmalley311
Carburetor Related
Jul 6, 2015 02:40 PM
Ouch
Carburetor Related
Jul 31, 2014 01:56 PM
xfry
May 5, 2013 11:56 PM
bikerlaw
Exhaust System Topics
Jun 17, 2010 09:54 PM
JZscoot
Ironhead
Jul 2, 2009 12:48 AM
