Blinker Problem
Old Nov 27, 2008 | 08:23 AM
jimmyg61400's Avatar
jimmyg61400
Default Blinker Problem
I have 06 Ultra. My left blinker blinks normal for about 4 blinks then blinks double or triple time. The bulb was replaced about a month ago. Is this a flasher problem, if so how do i replace it. If not, what is the problem
Thanks
Jimmy
Old Nov 28, 2008 | 03:51 AM
Hawgnut's Avatar
Hawgnut
Default might be tough to find
Don't sound like the flasher, doesn't it work all 4 turn signals? Not real sure about that....Have you cleaned up the sockets good? checked for good ground, Have you looked under the handle bar controls yet could have a stray wire touching in side. if you have a test light and a good volt meter you should be able to find it Good Luck Dude
Old Nov 28, 2008 | 04:45 AM
Hawgnut's Avatar
Hawgnut
Default Tech tip help
Jimmy just going thru the forum and found a thread that might help you out with your problem .. Look under "Tech tips" in this forum, there is only one thread about blinker lights and it sounds like what you need...........
Old Nov 28, 2008 | 10:09 AM
jimmyg61400
Default Thanks
Thanks for the info...
ChaseDWG
Nov 13, 2018 08:47 PM
Teddy1983
Apr 3, 2017 12:42 AM
Cap'n Parrothead
Electrical/Lighting/Alarm
Jun 28, 2013 08:42 AM
agst187
May 11, 2012 04:26 AM
harleycax
Aug 11, 2010 11:56 PM
