Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
i have a 04 ultra i just had a power commander and vance&hines headers put on and dyno it it has screaming eagles mufflers i got 67hp and 80ft lb of tourq but it back fires alot on decel the dealer says thats nomal help
Are you sure it isn't Lean Pop that you are hearing.... When you roll off the throttle, you hear a pop or light crack out of the exhaust...
Whoever did the Dyno Tuning failed to properly tune it.... That is not normal with a properly tuned PC...
Dealer is BS'ing you.... They did a sloppy job and got you to bite... Did it do it before???
Absolute Truth. With a SERT or Power Commander and a good dyno tune you eliminate the back firing and popping. Like mentioned above, your dealer is B.S. ing you. Not everyone is competent running a dyno. Check around or take it back and let them know you are not happy.
