SEST closed loop questions?
Old Jan 18, 2009 | 08:46 PM
TODDNVAL's Avatar
TODDNVAL
Default SEST closed loop questions?
Hi all, I'm still trying to get a better understanding of the SEST, I'm interested in the closed loop mode. I thought that the AFR tables highlighted in red(14.6) were the areas that the bike runs in closed loop, the map I'm using has the AFR to 14.6 up to 80%kpa and through 3750 rpms. I can pull up the closed loop bias table and it only has settings up to 3000 rpms but goes up through 100%kpa, is the bike still in closed loop from 3000-3750 and is there a reason for 90-100%kpa adjustment? I also have looked at other maps and on 07 bike maps there is a CLB table for each cylinder but only 1 table for the 08-09 bikes why is this? If I understand the CLB tables correctly 780mv would make the AFR more like 14.1 instead of 14.6 but would still be working in CL mode.
Old Jan 19, 2009 | 03:42 PM
Crazycalvin's Avatar
Crazycalvin
If you are asking what the color red means, I thought that it meant that the value in the "Red Cell" could not be increased past the value that was in the cell. Also a value in a "Green Cell" could not be lowered below what was there. Hopefully someone else will chime in about the bias tables and when you run in closed loop. Later, Calvin.
Gozzie
The Dyno Room
May 11, 2017 12:29 PM
marty442
Exhaust System Topics
Jan 14, 2011 05:55 PM
ubreal
Mar 22, 2009 10:06 AM
TODDNVAL
Jan 18, 2009 08:48 PM
DTK
Sep 21, 2006 11:10 PM
