Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Fixed a leak in the manifold and putting the tank back in place, re-syncing the ignition timing with the idle as per the service manual (clymer).
It seems to be misfiring, almost like the timing is off. I thought I would pass it by you "experts" before I remove the tank again and do the resistance test on the ignition coil. I suppose the mundane tests such as spark plug and spark plug wires are needed as well.
Forgot the necessary info
'03 RKClassic. EFI. PCIII. Gear driven Supercharger. V&H Dresser duals.
had 10k service professionally done (if you can call it that)w/ synthetic and HD primary. currently 12k.
