Popping
Old Jan 21, 2009 | 04:26 PM
BarryN's Avatar
BarryN
Default Popping
I have a 07 softail and I put on V&H long shots, AC, sert and had it dyno. I now have a popping in deceleration but over time it has not gotten worse.
Is there a chance that is jump timing? Any thoughts?
Hope this is the right thread for this topic.
THANKS!
Old Jan 22, 2009 | 10:40 AM
RK_RIDER's Avatar
RK_RIDER
Most likley you hav had a small exhuast leak form the beging and it is gatting worse with time. Check your clamps and gaskets. The rear cylinder exhuast gasket did this to me.
Old Jan 22, 2009 | 10:55 AM
BarryN's Avatar
BarryN
I will do that this week-end.
Old Jan 22, 2009 | 11:12 AM
Phlip96's Avatar
Phlip96
its easiest to check for this leak when you first start the bike cold. have your hand around the joints (not literally, 1/4"-1/2" away) for inspections before it gets too hot to handle.
Old Jan 22, 2009 | 12:04 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
When you installed the V&H pipes did you replace the exhaust gaskets or re-use the old ones?
Old Jan 22, 2009 | 08:10 PM
murphdog's Avatar
murphdog
If you don't find any exhaust leaks and you have a copy of your Race Tuner map, try taking out some decel enleanment. I had to decrement mine about 0.20 to get rid of all the popping at warmed up temps.
Old Jan 22, 2009 | 08:20 PM
H2OFOOTER's Avatar
H2OFOOTER
My bike started popping bad and then started missing at 8500 miles, found my spark plugs were fouled I think fuel additives.I installed new plugs and all better now.
hardheaded
Milwaukee Eight (M8)
11
Sep 5, 2017 11:23 AM
JefferiesHD1
Exhaust System Topics
Mar 16, 2013 11:11 AM
mostSilly
EVO
Aug 3, 2010 10:10 PM
I8SMK4U
EVO
32
Feb 6, 2010 04:46 AM
sonicporno
May 26, 2008 11:49 PM
