Basic SERT question from a beginner
Old Apr 17, 2006 | 01:08 PM
MikeO's Avatar
MikeO
Default Basic SERT question from a beginner
I’m new to the SERT so please excuse my beginner questions, I’m just starting to learn.
1. Is there a way to save the default map that the bike comes with so I can go back to it if I need to?
2. I have the 32107-01 D SERT. Now that the E version is out how much different is the
Cal #32 -- 141NX001-A0.MT6 in the E version than the D version?
Is there anyway to get a hold of the E version, or can anyone tell me the changes so I can create the newer file to get started.
Or are there so many changes I’m just out of luck?
Thanks…
Old Apr 17, 2006 | 05:08 PM
PowerCobra98's Avatar
PowerCobra98
Default RE: Basic SERT question from a beginner
Question 1: No. Once you copy over it that's all she wrote. You won't miss it though.
Question2: I'm assuming you have an 06 Dyna. On the E disc there is a 141NX001 file and 141NX002 file. The 002 is the more recent version of the map. There are many changes between the files and 002 is clearly better (or at least it has more places to modify cells). If you email me I will email you the most recent file. To make sure though check which fuel injectors you have. If you have 8 degree injectors then this is the file you need. If you have 25's then there is a different file that I can send as well.
masterblaster
May 10, 2008 12:18 PM
rider
Jan 23, 2008 09:00 PM
cjike
Jul 3, 2007 07:34 PM
double_d90
Apr 21, 2007 09:41 PM
Smittyjf
Sep 6, 2006 09:42 PM
