Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Hi Everyone,
I've used a Powercommander in the past and understand EFI completly, so this may sound stupid since I'm new to SERT.
PC maps always had the values it was adding to the ECM table in the cells.
Sert maps don't show anything.
Is this just to show adjustments to the base map (Which you can't see)?
I see the set baseline and set reference buttons, so I'm assuming that it only shows my edits.
Is this correct?
Smitty
Go back into the tune mode, load the map you want, Under the setting tab select advanced mode and the cells will populate.
That I did see originally, but the cells that populate are not the fuel table. They are the AF ratio, VE and timing. I have (since my original post) pretty much completly understand the SERT.
In my original post, Since I was so used to seeing what the PC was adding to the ECM values, I was just wondering if it was just showing your edits (Which is the case)
Just a little getting used to was all.
Thanks,
Smitty
