Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
is there any easy way to adjust the tps sensor?/
my 08 ultra is reading 4.5% at idle.. and my tuner says that
will mess up my tune... i cant find anything in the service manual about adjusting it??/ help
thanks
burgie
i would still think that 0% is what is needed at idle??
hot or cold ... tgs??? i dont suppose anyone with the elect manual would post the tuning specs for the tps???
thanks
burgie
Originally Posted by Shovelhead Bob
2.5-4.5% is normal at operating temp.....
0% is completely closed off....
TGS systems are a little different.....
You will find the specs in the Electrical Diagnostics Manual....
Your bike is a Drive by Wire bike ie: has no throttle cable. HD calles the handle bar throttle a TGS. That stands for Twist Grip Sensor. Since the throttle blade also has a sensor that is called TPS for Throttle Position Sensor. As Bob stated the tps will run 2 - 5% as the ECM is controling the blade position to control idle speed. If it closed the blade your bike would not run. It seems your tuner is a little behind the times and not up on the DBW bikes. For a cable throttle your tuner would be correct.
