Battery disconnect question
Old Feb 11, 2009 | 08:19 PM
strtarrow's Avatar
strtarrow
Default Battery disconnect question
I bought a set of chrome control switches (turn signals, start, etc) and the instructions say to disconnect the battery. I recently put a new horn cover on and those instructions also had me disconnect the battery. Once I was finished I felt disconnecting the battery was a waste of time. Is this just a HD CYA or should I follow the instructions while replacing the switch covers? Thanks for the help and I did try a search before posting this but ran out of patience. Guess I need a xanax.....
Old Feb 11, 2009 | 08:59 PM
ngoti8tor's Avatar
ngoti8tor
This is just to cover HD's a$$ in case the bike accidentally starts.
I wouldn't disconnect the battery, but just make sure your ignition switch stays OFF while you change out those control switches.
Old Feb 12, 2009 | 05:27 PM
rbabos's Avatar
rbabos
Wouldn't hurt to pull the main fuse. That's easy. Good thing to do even when undoing the battery cables too, as it's complete one shot power interupt instead of the on and off light sparky contacts when undoing the terminal bolts. Don't think the ecm likes that much.
Ron
jahwarrior007
Electrical/Lighting/Alarm
Sep 6, 2017 11:12 PM
bootcampsam
Sep 18, 2016 09:28 AM
eric95
Mar 16, 2011 04:49 PM
stokes
Jan 2, 2011 11:28 PM
kennyjohn
Jun 19, 2010 08:11 AM
