Need help with basic SERT Download
Old May 1, 2006 | 01:47 PM
BUBBA's Avatar
BUBBA
Default Need help with basic SERT Download
I have the Newest Sert for the 06 E.
Do they Have Basic Down loads On The SERTS and do they show what down loads for your applications I have True Duals and the Air cleaner .
I would like to be able to drive My Bike to the Dealer For further Fine tuning and also a cam.
Old May 1, 2006 | 04:56 PM
ROADTRAIN's Avatar
ROADTRAIN
Default RE: Need help with basic SERT Download
there is a list of maps supplied with the SERT. Select on that is close to your mods and try it before taking the bike to a dealer, you may find it running ok.
Old May 2, 2006 | 02:35 AM
motoxlrg's Avatar
motoxlrg
See below, computer gliched!
Old May 2, 2006 | 02:49 AM
motoxlrg's Avatar
motoxlrg
Assuming you have installed the SERT on your computer. Check out calibration #27 in the oem calibration file. The description of the calibration is 2006 Touring Exhaust, stock motor, 8* injectors, SE/AC, SE performance mufflers. Obviously it's not a map built for the rineharts. But this download will be closest to your setup and will get you to the shop. If you plan to change to the 25* injectors, be sure to have that done before paying for a tune.
Old May 2, 2006 | 12:04 PM
BUBBA's Avatar
BUBBA
Thanks Jim Im going to give it a try this saturday.
will set up the computer in the garage
roadtrip
14
Nov 15, 2013 05:26 PM
gman
Dec 8, 2006 07:33 PM
CoolBreeze3646
11
Oct 11, 2006 03:23 AM
Caston
Mar 18, 2006 04:45 AM
JRAZ
Jan 5, 2006 10:54 PM
