engine light
Old Apr 28, 2006 | 11:51 PM
tennessee's Avatar
tennessee
3rd Gear
Default engine light
I have a 99 flhtcui with 37k miles....have never had any problems with the engine light untill today....I washed my bike today, just like I have before, and when I started it, the engine light came back on and stayed on for about 10 seconds and then went off....nothing else seemed to happen....so, the rest of the day everytime I would start, the red engine light would come back on for about 10 seconds and then go off....what is happening ????
Old Apr 28, 2006 | 11:55 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: engine light
You have a DTC (Diagnostic Trouble Code) In the ECM's memory....
This particular one is an Historic Code...
Meaning that something happened from the time before you washed your bike, to after, got "Tripped" in the memory...
Old Apr 29, 2006 | 12:04 AM
tennessee's Avatar
tennessee
3rd Gear
what do I need to do....is the dealer the only one to clear this code....I am getting ready to go out west on a 16 day ride....
Old Apr 29, 2006 | 09:34 AM
Uncle Peepers's Avatar
Uncle Peepers
The code will clear itself after 50 starts; or you can disconnect the battery for a few minutes; that will also clear the code.
Uncle Peepers
Old May 1, 2006 | 02:12 AM
landlords2's Avatar
landlords2
That answers my question also. Its happening to me. Before I clear it sure would like to know what it is and dont really want to bring ti to the stealership around here they are a bunch of *****.
Old May 1, 2006 | 09:07 AM
03 Softail's Avatar
03 Softail
I have an 03 Softail, same problem.
Has happen several times in the past two years. Bike will start, run and perform great, then for
no reason I will get the engine light, bike will still run great with no problems.
Take it to the dealer they erase the code and I'm off and running, untill it happens again.Never know when that will be. The last time I took it to the dealer, they said the code was
an open circuit?, but everything on the bike works.
I beleive I've gotten this code a total of 5 times.
Sure would like to know why this keeps happening.
Dan
Old May 2, 2006 | 10:36 AM
tennessee's Avatar
tennessee
3rd Gear
[:@]I talked to my dealer and was told that it was probably a low voltage history code, probably caused when I started and is not a problem and it would clear in 50 starts....shouldn't be a problem....
Old May 3, 2006 | 07:53 AM
03 Softail's Avatar
03 Softail
Thanks for the information.
Ride Safe
mikeferns
May 2, 2018 07:45 PM
chizman
May 15, 2011 04:35 PM
scooby doo
May 18, 2009 07:59 PM
jrspringer06
Oct 26, 2008 06:08 PM
20NightTrain03
Jul 6, 2006 12:00 AM
