Relay problems
Old Apr 15, 2009 | 06:50 PM
Scooter68's Avatar
Scooter68
Default Relay problems
I'm having trouble with my accessory switches. OK here's the deal the three switches on the handlebars are hooked up to relays. Now there are four relays under the seat, one is M (master) then #1, #2 and #3. The number one switch is hooked up to my lower driving fog lights, #2 is hooked up to my lights on the saddlebags and back of pass footboard, and three was empty. Well I hooked up #3 to my Light ring around the rotor. So here's the problem the two worked before and now none of them work. I used an ohm meter and have power from the switches to each relay, and also used a jumper wire and there is power to each set of lights. Each relay has a inline fuse also and none of them have blown. So my next question is what do I do next, and where do I look for the problem? Any help would be greatly apperciated, Scott.
runnhrd
Electrical/Lighting/Alarm
Aug 27, 2015 06:19 AM
jb27
May 3, 2012 09:50 PM
Scooter68
Apr 29, 2009 08:26 AM
Jukebox
Feb 19, 2009 06:20 PM
yodal
Jun 16, 2005 02:05 PM
