Need Help
Old Apr 17, 2009 | 09:06 AM
hammermeistert's Avatar
hammermeistert
Stage I
Default Need Help
I have a problem I Put my battery in this spring and went to start it and all I get is a click in the relay nothing on the starter help please
Old Apr 17, 2009 | 10:06 AM
GONZEE's Avatar
GONZEE
same problem here. im sure im overlooking somthing stupid and obvious but i just cant figure it out.
Old Apr 17, 2009 | 01:25 PM
chester1957's Avatar
chester1957
Did you charge your battery over the winter. I'd make sure I have a fully charged battery and then double check your connections. While pulling the battery out and keeping it in a warm place reduces voltage drop, it doesn't completely eliminate it.
Old Apr 17, 2009 | 09:59 PM
jmetro's Avatar
jmetro
use a jumper between the flag terminal on the starter and the direct batt connection on the starter. if it doesn't crank over, its your starter. if it does its the wire between your relay and the flag terminal.
londonking
Mar 17, 2024 10:43 AM
martinez_nc
Feb 23, 2013 02:35 PM
razman427
Nov 2, 2012 06:03 PM
texashillcountry
EVO
36
Mar 21, 2012 09:55 PM
superglazier
Jun 9, 2007 12:19 PM
