sert pro
Old Apr 18, 2009 | 03:17 PM
rocker00's Avatar
rocker00
Default sert pro
hi guys i have version 32114-01a.....just wondering if it will work on my 08 rocker......it said it would from where i bought it but now the cables will not connect to my bike.....just wondeirng what is going on.(im new to bike tuning). thanks guys
Old Apr 18, 2009 | 03:49 PM
scotty3's Avatar
scotty3
You should have a little black box, a 9 pin serial cable male-female to hook up between your computer and the little black box and a 9 pin female serial to 4 pin female Deutsch cable to hook up from the little black box to the plug under the seat on the Rocker.
You will need software v4.77 as that was the last one made and the only one that will work on the 08 Rocker.
Having said all that you should be told you have bought a product that has been obsolete for nearly 18 months and has no support.
You should have bought a TTS tuner.
Old Apr 19, 2009 | 11:25 AM
rocker00's Avatar
rocker00
yes but i bought it off of ebay for 115 dollars new in box so i figured it cant get much better than that
Old Apr 19, 2009 | 03:48 PM
scotty3's Avatar
scotty3
Well as long as your happy that is all that matter in the end.
Did you work out the cables as that is what your original question was all about.
Old Apr 20, 2009 | 12:28 PM
ToBeFrank's Avatar
ToBeFrank
Plus using some other software to do the tuning and you're getting the same result for less than half the cost of the TTS.
RA51
Mar 4, 2011 11:15 PM
Beman
Jan 8, 2008 06:25 AM
Road Glider
Oct 1, 2007 08:09 PM
DaveC670
17
Aug 9, 2006 06:08 PM
fiddledicksr
Feb 19, 2006 04:21 AM
