Turn signal problem
the past 12 years. The rear lens are red and act as running lights and
signal lights. No problems until today. I noticed the left side, front and
rear, does not flash as bright. When I first activate the left signal, it
flashes once normal and then it dims considerably. It continues to flash,
but not nearly as bright as the right side. While the left side is flashing
weakly, the right side dims slightly on every flash. Also, what is the
correct bulb for this set-up? I've had people tell me 1157, 2057, and
also 198(or 1198).
