Thundermax rocks!
Old May 29, 2009 | 07:45 AM
texas-buzzard's Avatar
texas-buzzard
Default Thundermax rocks!
It's not cheap but you get what you pay for. Installed in 15 min, loaded map, lowered my idle and went riding while the auto tune adjusted my A/F. It is plug and play with no issues found. Software is user friendly.
Old May 29, 2009 | 09:43 AM
Zacharia_11's Avatar
Zacharia_11
What did you lower you idle too? Just lookin out, but make sure not to drop it under 900RPM as you should be above that to miantain proper oil pressure.
Old May 29, 2009 | 10:15 AM
texas-buzzard
I dropped it from 1050 to 910. Sounds great thru my V&H big radius pipes.
Old May 29, 2009 | 11:08 AM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
Been considering the Thundermax. I've got a SERT and I've been tweaking the system, but w/out any real feedback from and exhaust gas analyzer and or dyno I think your somewhat limited. So I think the Thundermax system w/AutoTune based on wideband O2 sensors might be the ticket.
I don't believe the 900 rpm for proper oil pressure idea. Can anyone trace this back to real hard documentation, or is this just anectdotal. I've also heard the alternator doesn't put out enough voltage at anything lower than 1k. So who sits idling long enough to run the battery dead? I had a 94 FXDL that idled about 750. Never any oil pressure issues w/that bike as long as I had it. Certainly the oil pump on my 2008 FXDF can do as well. I've got it idling at 800 rpm. Low as it would go.
Old May 29, 2009 | 11:19 AM
Zacharia_11
Ok, its your bike. My 900 RPM is based off the documentation I recieved with my TTS tuning system.
Old May 29, 2009 | 12:06 PM
texas-buzzard
There are plenty of T/C bikes that idle at 750-850 rpm without any problems. I would like to find a post where there was an engine failure at these low idle points.
Old May 29, 2009 | 02:38 PM
jluvs2ride's Avatar
jluvs2ride
Well, this is absolutely the first I've ever heard of any one pointing to any documentation concerning this issue.
I would be interested in maybe seeing what an actual oil pressure gauge reads at 800, 900, and 1k rpms.
Old May 29, 2009 | 06:40 PM
rbabos's Avatar
rbabos
It varys between engines. I had mine at 900 once and it put out 12 psi hot idle pressure, and still had the 14 volt led blinking on the Kuryakyn informer. Don't see a major issue with lowering if you have data to back it up, like a good oil pressure gauge. Some only have 5 psi at 1000 rpms at idle. These are not good candidates for lowering. Eventually I end up back at my basic map setting of 944 as I'm not fond of a real low idle, but that's just me. At 944 rpm at same temp oil pressure might be tickling 13 as opposed to 12 at 900. I don't buy into the classic thought of these things being a flow more than pressure oiling system. True to a point , but you aint got flow if pressure isn't indicated. 5 psi at idle is seriously lame to oil the upper end. Flow, hit's restriction and registers pressure in the real world.
Ron
Old May 30, 2009 | 07:10 AM
msocko3's Avatar
msocko3
Lowering the idle is kind of like closing your eyes and kissing a fat chick, in the end you still kissed the fat chick and you bike sounds like a stock TC that needs a tune or is trying to be something it isn't.
Old May 30, 2009 | 07:49 AM
texas-buzzard
Do what, I'm lost on that one.
