Tuner/Battery
Old Jul 1, 2009 | 12:57 PM
badbag's Avatar
badbag
Default Tuner/Battery
Is it possible for a tuner to loose it's programming after a dead battery?
I didn't think so but my bilke is idling aweful rough after it happened.
Old Jul 1, 2009 | 01:30 PM
rbabos's Avatar
rbabos
Don't think so. It's flashed to a chip and retains it separately from battery power. If you are running a tmax then the initialize will need to be redone to set the iac for correct idle. This establishes the marriage between the mechanical iac device and the electronic control of the ecm.
Ron
Old Jul 2, 2009 | 07:43 AM
mpmillion's Avatar
mpmillion
Had the same thing happen. Wife was playing with the bike and left it on without knowing it. I jump on and the battery is dead so I had to get a new one. I lost the map that was in the PCiii, quick fix even though at first I had no idea what happened.
seniorsuperglideE8
The Dyno Room
Sep 17, 2016 07:31 AM
martin10
Sep 5, 2014 11:09 AM
Tesla_HV
Apr 26, 2013 11:08 AM
HighLiner
Jul 2, 2012 09:13 PM
confused
Nov 20, 2008 07:33 AM
