Engine cuts out
Old Jul 7, 2009 | 12:49 PM
sphoad's Avatar
sphoad
6th Gear
Angry Engine cuts out
I have an 07 Heritage with an intermittent problem. When I am slowing down for a junction using engine braking and pull the clutch in, the engine stops. It does not splutter, the revs just drop off. It will imediately restart. The really annoying bit is that it does not do this all the time, so it is really difficult to find. It has had a Stage 1 and I have a PC III fitted and have had it taken out and still get the problem. Even had the run switch wired out but still the problem persists. Any suggestions or hints welcomed.
Old Jul 7, 2009 | 12:58 PM
1of2's Avatar
1of2
"Moderator"
Could it be happening when the parade mode comes on?
Old Jul 7, 2009 | 01:06 PM
Blackcherry Low's Avatar
Blackcherry Low
You might check and see if you have any DTCs logged.
Old Jul 7, 2009 | 01:24 PM
sphoad's Avatar
sphoad
6th Gear
Thanks guys,
I should have said that there are no logged faults. Not sure if the bike has parade mode but this happens when slowing down from quick runs as well. If I keep the throttle open just a little then the engine keeps going. Weird ...
Old Jul 8, 2009 | 07:03 AM
TickTock's Avatar
TickTock
Check your Crank Position Sensor.
Old Jul 8, 2009 | 05:50 PM
Old Gunny's Avatar
Old Gunny
And the IAC setting. This is supposed to swing into action and help catch the idle if it drops below setting
Ron750
Jun 4, 2019 01:15 PM
VDeuce
Milwaukee Eight (M8)
Feb 26, 2018 02:31 PM
TravelingBiker
The General Motorcycle Forum
89
Aug 28, 2012 05:58 AM
lagrand
May 2, 2009 01:40 PM
cglofland
Apr 30, 2008 07:26 PM
