voltmeter question
Old May 26, 2006 | 07:14 PM
locutus's Avatar
locutus
Default voltmeter question
is it normal for the voltmeter to dip down to 10 or less when stopped at a light with the brake on and turnsignals flashing? as soon as i pull away the voltmeter goes to 14.
Old May 26, 2006 | 07:52 PM
Pat's Avatar
Pat
Default RE: voltmeter question
That does seem a bit low. How old is your battery? How is the fluid level in the cells?
Old May 26, 2006 | 08:27 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Don't trust that Gauge.....
It is NOT CALIBRATED.....
Hook up a DVOM (Digotal Volt-Ohm Meter).... Load the system (Turn EVERYTHING on)....
your batt voltage should be 13 to 13.5 vdc @ 1000 rpm (Idle).....
As your RPM's increase, so should the voltage to the batt.....
IF IT DOES NOT RAISE, This will tell you that the Regulator or Stator is failing....
If this pans out, check voltage before and after a lengthy ride (50 miles)....
Load the system as much as possible (High beam, lots of T/S, Radio [if applicable])....
if voltage is same or lower, your batt is failing....
Minor edit above in bold....
Old May 26, 2006 | 10:39 PM
tripl8's Avatar
tripl8
"As your RPM's increase, so should the voltage to the batt.....
This will tell you that the Regulator or Stator is failing.... " say what ?????
Old May 29, 2006 | 06:03 PM
RED E GLIDE's Avatar
RED E GLIDE
If the idle RPM is too low it will also effect the charging system output, even when the battery and charging system
are in good condition.This is why fuel injected Baggers are programmed to idle at 1000 RPM.
Like Shovelhead Bob said, never assume the factory gauge is correct.
That said, you could have a battery or charging system problem if if idle is O.K..
Old May 29, 2006 | 08:07 PM
locutus's Avatar
locutus
i've come to the conclusion the voltage regulator is at fault. battery shows correct voltage. stator voltage increases with rpm. battery shows no increase with rpm. no short to ground from stator. do you all agree? also bike blows circuit breaker intermitently next to the battery when brakes and turnsignals are applied. voltmeter dips to 10. battery is new and fully charged.
kevjo
Sep 10, 2018 06:51 PM
green hd
Jun 7, 2015 08:47 PM
t059736
May 24, 2012 09:21 AM
flagshipjoe
Nov 24, 2011 01:09 PM
trackadaptor
Oct 16, 2011 10:24 AM
