feels limited...
Old Sep 15, 2009 | 06:13 AM
kuxika's Avatar
kuxika
Default feels limited...
Is there a rev limiter on the vrscaw? If so how do you get rid of it? Please be detailed I'm new to HD's thanks. Will it affect the warranty?
Old Sep 15, 2009 | 10:09 AM
genedjr's Avatar
genedjr
There is a rev limiter on all EFI bikes. It keeps you from damaging the engine. The rev limiter is set in the ECM.
What exactly are you experiencing? Strong pull upto a point followed by a sudden hesitation? Then yes you have hit the rev limiter.
First, if you change the rev limiter to a higher value than what was set by the factory, you may run into warranty issues.
Second, you will need a ECM program to change this value. Or a ECM replacement like Thundermax to gain access to changing engine control parameters.
I would kindly suggest, shifting gears
...gene
Chad Lewis
Milwaukee Eight (M8)
Feb 11, 2019 06:29 AM
blinkwatt
Dec 18, 2017 01:46 PM
wvedec
Jul 3, 2014 10:25 AM
Fritzables
May 4, 2014 01:28 AM
TickTock
Mar 26, 2007 10:30 AM
