Thundermax- installing modified map
Old Sep 23, 2009 | 05:03 AM
nevil's Avatar
nevil
Default Thundermax- installing modified map
The Zippers tuning manual isn't clear on this and I don't want to mess it up.
I have a modified map that I need to install and want to know the steps involved. Is it the same as installing a base map, where you write module map & settings, clear learned fuel adjustments, clear idle adjustments, initialize and run IAC Auto?
Or is there another procedure?
Old Sep 23, 2009 | 09:45 PM
davidwideglide06's Avatar
davidwideglide06
That is pretty much it. If I modify the map I already had and say just adjust afr or something similiar, then no need to redo the Iac procedure.
flyingdutchman
The Dyno Room
Sep 13, 2016 01:08 PM
gwk
Aug 14, 2015 11:17 PM
WARG
Sep 20, 2008 06:00 PM
spider445
Oct 23, 2007 10:20 PM
Roodog
Jun 25, 2007 02:53 PM
