Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I´m from Brazil and all guys here has no much experience with the SERT.
I have a FLST 06 with the following set up:
SE II mufflers + SE AC + SE 203 Cam
Which is the best file to start?
Thanks for any help
Mário
I have just started using this SERT so I'm no pro. I believe your cams are going to throw the V/E tables off.
Without the cams there is a map file on the disk that will conform with the rest of your setup. There is a .pdf
file on the disk called "Delphi race tuner cals" use the one that is closest to your setup.
You might want to check with hdmaps.com. $69 U.S. for MAPS.
