Sert map suggestion?
Old Jun 28, 2006 | 12:22 PM
TKanaley's Avatar
TKanaley
Default Sert map suggestion?
I'm scheduled to have my RKC dynoed the middle of next month, but I would like to install the components now. The engine is 06 stock with 25 degree injectors. I'm adding V&H dresser duals, with SE performance touring muffs and K&N RK-3909 AC. The map I'm looking at using is:
#55: 2006 Touring exhaust
Configuration: 1450 SE A/C and Mufflers
File Name: 141NR004-A0.MT6
Components:
25deg Injectors
SE Air Cleaner and Breather kit
SE performance Touring mufflers
Is there a better map, more suitable to my components? I just need to get it close. Thanks!
Old Jun 29, 2006 | 03:04 AM
WS6 Formula's Avatar
WS6 Formula
Default RE: Sert map suggestion?
Install the 141NR004-A0.MT6 map then try the 8* map 141NR101-A0.MT6 and see which one runs better.
Old Jun 29, 2006 | 09:20 AM
Nomad2day's Avatar
Nomad2day
I have a 06 RK Custom with a stage 1 download, 25* injectors, V & H true dual headers, SE slash cut performance mufflers and the SE A/C with a SERT installed. I started out with the #55: 2006 Touring exhaust Configuration: 1450 SE A/C and Mufflers File Name: 141NR004-A0.MT6 but got a lot of popping on decel.
I tried Calibration # 57: 2006 Touring Exhaust Configuration: 1550 SE A/C & Mufflers File Name: 141NS002-A0.MT6
I am still running this one # 57 with no more popping until I get dyno tuned.
Neil
Old Jun 29, 2006 | 02:24 PM
TKanaley's Avatar
TKanaley
Thanks to all, for the suggestions both on and off the board!
Now I just need to find the time to hook the stuff up!
Old Jul 4, 2006 | 01:35 AM
YankeeBob's Avatar
YankeeBob
Is a RKC a Road King Classic or a Custom?
Try using the proper alphabet. FLHRCI or FLHRSI
HEYENG
Mar 19, 2008 09:07 PM
voodoodrug
Sep 5, 2007 10:35 PM
sprinter1551
Jul 26, 2006 02:45 PM
ScottFLHX
Exhaust System Topics
Jun 13, 2006 01:16 AM
brlowe
Mar 9, 2006 12:49 PM
