Tuning SERT for better gas mileage?
Old Nov 4, 2009 | 05:28 PM
jimclaypool's Avatar
jimclaypool
Default Tuning SERT for better gas mileage?
Is there something simple to tune a SERT for better gas mileage? My '07 Ultra (SEAC and SE exhaust) gets in the 40-45 mpg range on country roads running 45-50 mph. Get on the Interstate doing 75-80mph and my gas mileage drops to 35mpg or less. That is what I experienced this summer on a 7,000 mile trip over 21 days out west. I just uploaded the one canned map for my set up. Bike runs great, but I would like better mpg on the Interstates. I think I just need to change a few of the a/f ratios on the map, but not sure where to start. Any help?
Jim
07 Ultra
Old Nov 4, 2009 | 08:07 PM
Shovelhead Bob's Avatar
Shovelhead Bob
You need to have the VE tables and the CLB tables dialed in....
Best way to do it is to invest in a QUALITY Dyno Tune session...
A canned map is just a STARTING POINT... for optimum power, performance and economy, you need to get it tweaked in...
Old Nov 4, 2009 | 09:02 PM
producer's Avatar
producer
Thumbs up
Ditto to you Bob.
I want to add something. If you have the time and some extra money, maybe consider porting your stock heads and a slight bump in the cam. you will be surprised at how much better gas mileage you will get with that extra power.
I'm very happy with what I did to mine. Just an example and I wouldn't recommend this as a test for mileage; but this past summer I ran one leg of a trip at 80-89 miles per hour and I still got 42 miles per gallon. Now, I'm running a 6 speed SE transmission too. But when you consider my big fat ultra fair sail that's pretty good.
Old Nov 5, 2009 | 09:33 PM
jimclaypool
Bob, I hear you, BUT, is there not something that I could try that may help. I am very happy with the power and performance of my Ultra currently. It is loaded with the canned map #78. I am thinking that if I just lower the CLB table values for both cylinders in the 2000 & 2500 rpm in the 30-60 kPa range that I should see an economy improvement on cruising on the interstates. What do you think about that?
Thanks for any help
Jim
Old Nov 6, 2009 | 06:52 PM
Shovelhead Bob
Thanks for any help
Jim
You don't lower the CLB numbers, you raise them to get a fatter, but more responsive Closed Loop area.... That still gets good mileage...
But... The VE's still need to be accurately dialed in to maximize the effect...
jjpish
May 12, 2012 08:23 PM
jandlcars
Apr 25, 2008 10:19 PM
Nellybelle
Apr 3, 2007 11:40 PM
paulocouto
Nov 12, 2006 10:55 PM
dchoran
Nov 3, 2005 07:20 PM
