injector differences
Old Jul 16, 2006 | 08:50 PM
chopperchuck's Avatar
chopperchuck
Default injector differences
what is the difference between a 27709-06A screamin eagle(25deg) and a 27654-06 injector which comes installed in the 50mm induction module? what are the flow rates for each and is the spray pattern different on the 27654-06?
Old Jul 17, 2006 | 09:10 PM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
Default RE: injector differences
8 degree injectors have 3 holes
25 degree injectors have 6 holes
50 mm t body is a high flow 3 hole injector. Don't know the pattern in degrees
For flow rates see the EFI Tuner maps but remember, those are flow rates for calibrations, not actual flow rates of the injectors. Flow rates are given by manufacturers of injectors at a specific fuel pressure.
wydopn231
Apr 19, 2008 10:54 PM
RK_RIDER
Exhaust System Topics
Mar 24, 2008 11:41 AM
purple haze
Screamin Eagle CVO Models
Apr 3, 2007 01:14 AM
Hagar the Horrible
Mar 16, 2007 04:15 PM
zombie
Mar 8, 2007 01:47 AM
