Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
well ive been working on my dyna trike for some time now just bought new battery , sorted out ignition switch everything connected up set switch to run ,turned on ignition ,neutral light .oil light , came on on the dash . speedo lit up needle juddered , milage came up . small red symbol on speedo came on breifly and went out turned engine over did not fire up to set learn procedure , no turn signals either , headlights and tail , and horn work but nowt else any ideas wot i done wrong or how to remedy this please[:'(]
dyna is 01 carb model lowrider t/c according to diagram i got set run off sw/ to run ,turn on ign ,check engine lamp and security lamp illuminate, red light comes on for a few seconds on speedo then goes off engine turns over , does not fire, turn signals do not flash or work either, im stumped, crank sensor is new ,power to that ,speedo sensor is new power to that as i have neutral light [:@]
You need the bike to learn the new module code, otherwise marry the unit. Use this link https://www.hdforums.com/m_120188/tm.htmk . It is in the DIY section under fuel injections and alarms.
Just did mine today and it works fine. Besure to match ths key fob also. Must also set your own personal unlock code to use manually if needed.
thanks for info did not realise there are different ways of sorting out learning procedure it all gets a bit confusing , one states how to marry up new tsm ,other states how to relearn ecm and tsm well the marrying one did not work for me but the other relearn ecm,and tsm one did and she growls like a grizzly now straight through pipes music to my ears ,just a pity my old lady did not think so it woke her up outa bed and she gave me some ear bashin but sutch is life
