Spark Plug Wires
Old May 21, 2010 | 09:00 PM
jeffbcn's Avatar
jeffbcn
Default Spark Plug Wires
I searched here and both my Owners and Service Manuals and found nothing to tell me how often they should be changed. 06 Wide Glide 30,000 miles and runs great but I know that they can't last forever. Is it a good idea to replace them every once in a while? How often? Are stock wires OK? Screaming Eagle better? Aftermarket suggestions?
Old May 22, 2010 | 03:28 AM
msocko3's Avatar
msocko3
The service manual tells you to check the resistance as part of the normal service. If they don't fall within the recommended range then replace them. A couple years ago I had problem with how the bike was running. Did some data runs with the SERT and found boat loads of timing being removed and the bike would surge and pop. It turned out to be a bad plug wire which was confirmed by checking its resistance.
Old May 22, 2010 | 10:45 AM
Harlen Vega's Avatar
Harlen Vega
-Stock are as good as it gets for almost all applications.
-Screamin eagle are better if they make you feel better.
-Frequency of change is a matter of opinion and actual mechanical and structural failure based on a simple ohms test and/or tearing, cracking, dry rot etc. If memory serves me right they should be less then 1.0 ohm end to end. If 1.0 ohm and over then replace. Keep the good wires for backup or a buddy. I could be wrong about the less then 1 ohm so anyone please feel free to correct me if im wrong.
-As far as after market goes... if ya want colors then sure... otherwise... no real need unless your saving a few bucks.
-In regards to your 30k on those wires... pull them off, inspect them for cracks..etc do an ohms test and if they're good to go then they're good to go.
Old May 23, 2010 | 03:40 PM
bagga's Avatar
bagga
originals on my 85 yet. never had any problem with them. 90k.
Old May 24, 2010 | 05:46 AM
msocko3's Avatar
msocko3
Your 85 doesn't have ION sensing knock control so you can just ride it till it runs like **** then replace the wires. A bad wire on the modern bikes can raise all kinds of hell.
Old May 24, 2010 | 04:51 PM
bagga's Avatar
bagga
i thought my 85 was a modern bike.
Old May 25, 2010 | 01:29 PM
Old Gunny's Avatar
Old Gunny
I have fooled around with ignition things since I was a kid.
My folks 54 Chevy and a J C Whitney catalog all the way to Jacobs amplifiers for 2005 Corvetts
For the street
Something I have to keep telling myself is, A Spark is a Spark. The engine doesn't care.
The only thing that ever helped was new sparkplugs every 5-8K back when they put lead in gas.
nashspu
Sep 6, 2012 12:38 PM
snooper0069
Apr 25, 2010 02:37 PM
Ruralmed
Sep 18, 2009 05:11 PM
jose409
Apr 20, 2008 08:38 PM
scg
Sep 20, 2007 06:48 AM
