Electrical noise ?
Old May 22, 2010 | 08:00 AM
jhnmflr's Avatar
jhnmflr
Default Electrical noise ?
On my 87 Fxstc I seem to be having some electrical noise . I had removed cable driven speedo and went with a electric one , rear axle sensor etc . Ever since I had a bad fluctuation with speedo readings . Ended up putting in a 12volt inline regulator at harness to speedo and worked fine for about 500 miles . Now again I am fluctuating , touched the regulator and it is hot , ran a different ground and same issue . my question is what causes said "noise" . I have checked charging system and I am at 14.3 @ at apx 2500/3000 rpm .
postalnut
Electrical/Lighting/Alarm
Sep 10, 2012 11:46 AM
postalnut
Sep 9, 2012 08:18 PM
HLChoppers
11
Aug 20, 2010 11:20 PM
jeramy
Jun 16, 2007 09:42 PM
blackfinbob
Jul 19, 2006 08:20 AM
