2003 Deuce EFI - Throttle pre startup normal?
Old May 25, 2010 | 07:25 PM
njdeucer's Avatar
njdeucer
6th Gear
Default 2003 Deuce EFI - Throttle pre startup normal?
I have my first fuel injected bike, an 03 Deuce. Is it normal to have to turn the throttle 2 or 3 times before cranking over? If I don't, first startup of the day takes a few cranks. Once it runs and I turn it off, it starts right back up. Its just on the initial startup where I have to do this. Not sure why it would need exta gas even with the EFI? When I do the throttle at pre crank, it starts as soon as I hit the start. Thanks!!!
Old Jun 9, 2010 | 05:52 AM
njdeucer's Avatar
njdeucer
6th Gear
Anyone?
Old Jun 10, 2010 | 02:36 PM
soundman's Avatar
soundman
No, you don't have to twist the throttle prior to cranking. The reason you do that with carbs is because it squirts a small stream of gas (via the accellerator pump) in the carb which helps during a cold cranking condition. EFI compensates with fuel enrichment during cranking. You may want to give it a few seconds to allow the fuel pump to pressurize the injectors prior to startup though.
Old Jun 16, 2010 | 03:33 PM
njdeucer's Avatar
njdeucer
6th Gear
I totally agree with you, and I stumped Harley with it too. Must be something with the pressure or air. Like I said, if I want a quick start with no cranking, I turn it 3 times...weird
Deucedog
General Topics/Tech Tips
Feb 14, 2016 09:51 AM
biggill
May 4, 2012 09:26 PM
dratliff
Mar 31, 2012 01:17 AM
river_rat
May 24, 2011 12:17 AM
kntrider_350
Jun 5, 2007 01:52 PM
