06 Deuce problem
Old Aug 25, 2006 | 07:05 PM
Championr1's Avatar
Championr1
Default 06 Deuce problem
Ok here one for the experts. When I turn on the ignition and flip the button to run, the bike starts without hitting the starter button. Then the bike wants to grind. Could there be a short somewhere? A fuse ? I just washed it today and figured it was water in one of the switches so I used the air compressor to dry everything, let it set for a few hours and still the same problem. Any help is much appreciated !!
Old Aug 25, 2006 | 07:28 PM
Geoseismic's Avatar
Geoseismic
Default RE: 06 Deuce problem
Sounds like your start button is permanently on "start", which is strange because, normally when they fail, they don't work at all. You probably have enough moisture in the switch that it is continuously making contact. I would either remove the switch and clean/dry thoroughly, or allow it to sit in a warm/dry environment for a couple of days and try it again. Hopefully your switch contacts have not fused closed. If they have, it may require replacement of the starter switch.
Old Aug 25, 2006 | 07:36 PM
Championr1's Avatar
Championr1
I'll take the switch out and try that. Thanks. I'll keep ya updated.
Old Aug 26, 2006 | 01:12 AM
Championr1's Avatar
Championr1
Those seem to be sealed units. Although they could be bad. any other suggestions ?
Old Aug 26, 2006 | 02:15 PM
Championr1's Avatar
Championr1
Ended up the switch was bad. Replaced and ready to ride [sm=biker2.gif]
Old Aug 26, 2006 | 06:18 PM
Geoseismic's Avatar
Geoseismic
Glad I could help! In the future, when washing your bike, try to avoid a direct spray of water on the switch housing's. I lightly wet them, but never spray directly on/in them.
HarleyDrifter
Aug 26, 2013 08:46 AM
Bo_Jangles
Nov 19, 2011 08:19 AM
Whir
Sep 25, 2011 05:37 AM
bloodyhead
Sep 5, 2010 08:56 AM
timeout
Mar 30, 2010 12:52 AM
