Got a tail light problem
Old Jul 4, 2010 | 01:46 PM
Vogelw's Avatar
Vogelw
Stage II
From: Currently Virginia Beach, Live in Austin, TX and Florida
Default Got a tail light problem
My brake lights work but the lights that stay on all the time don't work. Anyone have any suggestions?
Old Jul 4, 2010 | 04:20 PM
RICK IDE's Avatar
RICK IDE
Stage I
Have you changed your brake leaver ??? Some times they dont touch the brake sensor ....regards rick
Old Jul 4, 2010 | 04:37 PM
1flhtk4me's Avatar
1flhtk4me
If the bulb is a newer flat type that justs plugs in,crimp the socket a little so the bulb will fit tighter.
Old Jul 4, 2010 | 05:38 PM
mudrat_fat05's Avatar
mudrat_fat05
Check inside the bulb socket, the little wire that HD provides for a connection may have corroded enough to not make a contact. If so. clean inside the socket and using a small pick move the contact wire inside the socket to the center. Use dielectric grease to prevent further issues.
Old Jul 4, 2010 | 05:42 PM
RidemyEVO's Avatar
RidemyEVO
You sure the brake light isn't stuck on?
Old Jul 5, 2010 | 11:40 AM
HDConvertible's Avatar
HDConvertible
1st Gear
I had a similar problem when I changed to LED bulbs. It turned out that the solder spots on the bottom of the bulb had one shorter than the other and it wasn't making contact. I added a little solder and then filed them straight across. That solved that problem, but I had another problem with one of the other bulbs and (Yes it was Import) the outer casing of the bulb was slightly smaller than the American bulb and it would make intermittent contact from being loose. I didn't want to start messing with the bulb socket that had worked just fine with American made products, so I just junked the import bulbs and went with American made and they all worked fine. Another lesson learned. Hope this helps.
Old Jul 5, 2010 | 02:33 PM
asm481's Avatar
asm481
Pay attention readers, he said his brake light worked but the other (tail lights) do not work. Sorry OP I have nothing to offer then new bulbs and some dielectric grease.
snowboarder
Apr 13, 2023 12:09 PM
dan_sandyrichards@sbcglobal.net
Electrical/Lighting/Alarm
Nov 2, 2017 03:27 PM
haligonian
Aug 26, 2012 01:19 PM
klf33
Jun 23, 2009 10:39 AM
NiteRider
Jul 26, 2007 10:47 PM
