06 Roadglide no spedo, tach,turn signals HELP!
Old Sep 2, 2006 | 07:55 PM
Dave L's Avatar
Dave L
Default 06 Roadglide no spedo, tach,turn signals HELP!
Hey people,
The last ride I was on I lost the headlights, the fuse was blown I changed it out and all ok. Today I lost my spedo and tach and front and back turn signals
and my cruise control. Front running lights work.
The alarm light stays lit on the spedo face and the signal lights flash when alarm is armed or disarmed. The headlight is working.
Every other gauge is working fine and the bike runs great.
I hope to be able to fix this at home as the stealer is almost 2 weeks for an appointment and they would probably look for the problem for hours and
then deny a warrenty claim trying to blame it on me.
Any help would be greatly appreciated
Thanks
Dave
[IMG]local://upfiles/4883/2ED3E560FE5F4D0594E25F7FEDA521E7.jpg[/IMG]
Old Sep 3, 2006 | 02:30 AM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
Default RE: 06 Roadglide no spedo, tach,turn signals HELP!
check the accessory fuse
Old Sep 4, 2006 | 01:39 PM
Dave L's Avatar
Dave L
Thanks One Screaming Eagle.
It was the accessory fuse, but what caused it and the headlight fuse to blow???
Dave
Old Sep 4, 2006 | 11:33 PM
One_Screamin_Eagle
ORIGINAL: Dave L
Dave
Thanks for the thanks.
Dave, my crystal ball has been broken for many moons now, but the most common things are pinched wires - did you install chrome switch housings or open them up for any reason - even to do grips? Or, something could be rubbed through somewhere. The best questions I can ask is "What exactlly has been done to the bike to change it from the way the factory produced it - including everything the dealer did as far as accessories, etc.?" This and "What was the last thing you did before you had the problem?" are pretty good starting points.
vtchopperdude
Feb 10, 2017 07:40 AM
TurkeyRun
May 27, 2016 12:21 PM
mglax13
Sep 29, 2015 08:56 PM
kmseitz
May 8, 2013 10:07 AM
jaydog
Apr 13, 2008 12:43 PM
