Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
and comparing it to the one already programmed in. I sort of understand the #'s and what the ones with the minus symbols mean in the 'cylinder' table but on the ignition portion I see on one map nothing but 8's all the way through the 100% throttle setting. What do these #'s denote in the ignition table?
The -# in the fuel table means a decrease in fuel. A positive number means an increase.
The 8 in the ignition area means your timing has been advanced 8*. If it were -8 it would mean there would be a -8* retard.
Does +8 (advance) at full throttle seem normal to you through the entire rpm range?
Trying to get a handle on the data inside these maps is somewhat confusing but at the same time almost understandable. The map on my bike right now for instance has +3 all through the idle column for fuel. Not sure why the throttle at idle would need to be rich. Ideally I would like to avoid another dyno run since they seem to be so hard on the bike, and it's rear tire specifically.
8 degrees seems like a lot especially in the 100% throttle range. If I were to see a map like that I would think someone just slapped a number in there and hopped like hell it didn't break anything.
A dyno is hard on a motor and other components and yes, you are right, a new tire won't be new anymore after a day on the dyno. There are other options to tune the PCIII. You can borrow a friends TTS and do a data run to see your timing retards during a full pull or street riding then change the PCIII settings. The TTS can't flash a map to your bike but it will register data runs on another bike other than the one it is married to.
Was this calibration installed on your PCIII by a tuner by using a dyno for another bike? I understand you are comparing two calibrations but from where and to what?
I'm going to try and post this map. It was don on a dyno for a stage 1 a/c and monster ovals. She runs really well but quite rich at the idle which you see. Maybe those with knowledge about this stuff will pipe in with their opinions. Ok, so I can't post it since I figure out how to send a pvm file.
