1990 Fl High Torque Starter
Old Sep 3, 2010 | 11:48 AM
100inchbagger's Avatar
100inchbagger
Stage I
Default 1990 Fl High Torque Starter
Hey Now, I a Newbie. I have a 1990 FLH with a 100 cu.in. Revtech engine with compression releases. I sent it to a local shop for some minor carb work. Apparently the guy was starting the bike without using the compression releases. Now I have a starter with broken teeth on the starter motor shaft and clutch teeth. I would like to move up to a high torque starter but the ones I find seem to be too big to fit in the frame. As in the starter motor is to long. I don't think the stock starter is worth rebuilding, as the whole motor will require replacement as well as the clutch gears. This is a real bummer. Any Ideas? Thanks guys. John
FL54
Shovelhead
44
Jan 24, 2018 08:31 AM
zenon9
EVO
Dec 30, 2007 05:05 PM
02glide
Oct 26, 2006 01:00 AM
shedtech
Oct 19, 2006 07:37 PM
Night_Train01
Sep 11, 2006 06:10 PM
