FYI article on DFO
Old Jun 20, 2005 | 02:44 AM
Iron Horse's Avatar
Iron Horse
Default FYI article on DFO
I read the DIY artical on setting the DFO ,What's a DFO?and where's it located? and where are the pot's located ? (besides in the kitchen)
Old Jun 20, 2005 | 09:03 AM
HDF Tech's Avatar
HDF Tech
Default RE: FYI article on DFO
The DFO/TFI (same thing) is a digital fuel optimizer used on fuel injected bikes to richen up the fuel mixture and is wired in after the ECM so it changes or lengthens the pulse width on the fuel injectors . They work very well and require very little fuss to set up. They only ADD fuel unlike the power commander where you can add or remove fuel or timing. The pots are small screws that are potentiometers that change the electrical value as mentioned above
Here's a link if you would like to check it out http://www.dobeckperformance.com/dfo/
Both the DFO/TFI are made by techlusion , the TFI is sold by them and the DFO is distributed for sale by other companies like custom chrome etc.
coyotedream1
Apr 7, 2016 09:14 AM
GWinkleman
Jan 3, 2012 06:29 PM
mgalfano
Dec 30, 2007 09:29 PM
sifularson
Dec 21, 2007 01:42 AM
charlie1
Feb 14, 2005 09:02 PM
