Dyna Fat Bob Relay Problems
Old Sep 16, 2010 | 12:21 AM
Tom_M's Avatar
Tom_M
Default Dyna Fat Bob Relay Problems
I have an 09 Fat Bob and have had three relay failures since I bought it in September 08, two system relays and one starter relay have failed. The first time I had a system relay go I wound up pushing the bike home the starter relay went next but I was still in the garage by the time the second system relay went I was already riding with a pocket full of spares. It's out of warranty now so I've gottaa fix it myself now, I'm just not sure if this is an inherent problem with these bikes or I have something wrong that is damaging the relays. Has anyone had the same problem? If so have you found the solution? Help please! I want to leave on the bike without a pocket full of relays for once!!!
Old Sep 16, 2010 | 09:16 AM
planethax's Avatar
planethax
Check this thread.
https://www.hdforums.com/forum/dyna-...tem-relay.html
Ur in a Humid High Moisture area?
May be a good Idea to clean all contacts and use dielectric grease on them.
Old Sep 16, 2010 | 06:27 PM
Tom_M's Avatar
Tom_M
Thanks for the link, sounds like I'm not the only one with relay issues. Too bad there are no fixes for it. Not too much humidity here and I don't ride in the rain if I can help it but the fuse box on my bike gets really wet every time it's washed. I blow it out and keep all the connectors covered in dielectric grease and I was pretty sure corrosion was the issue until I cut one of them open and found that the contacts were burnt. I think it might just come down to $hitty components.
Old Sep 17, 2010 | 10:30 AM
planethax's Avatar
planethax
Poor connections and corrosion can cause heat to increase that will burn contacts.
Think it is a bit of both, weak components (under rated) and the increased likely-hood of corrosion due to location of components.
Geriden
Feb 14, 2019 09:53 PM
dawroz
Jan 16, 2016 09:38 AM
Ruckus_08
Jan 8, 2015 06:05 AM
tryan31
Jan 14, 2013 11:50 AM
JabbaPK
Jan 27, 2009 07:51 AM
