Bad Stator - Underlying Problems?
Old Sep 17, 2010 | 01:29 PM
usmcdevildog's Avatar
usmcdevildog
Default Bad Stator - Underlying Problems?
History: 2001 FLHTCI, just replaced old (bad) battery and still not charging. Oil in voltage regulator/stator plug.
I have taken the old stator and voltage regulator off and have new ones on the way. Looking at the old stator, the entire thing is black. You can't even tell that this is copper. Obviously it's burnt up. Is that what a burnt up stator is supposed to look like or should I be looking for another problem.
Also, since I have the primary cover off, is there anything else that I should replace? (ie: seals and whatnot)
Thanks
1999evo
EVO
13
May 23, 2016 10:05 PM
diiulio
Apr 22, 2010 04:01 PM
byronrub
Jun 10, 2009 12:07 PM
Sleeps In Trees
Oct 23, 2008 07:52 PM
hawg50
Sep 17, 2007 08:44 AM
