starting problem
Old Sep 25, 2010 | 10:46 AM
TM82's Avatar
TM82
Stage II
Default starting problem
Hey im new to harley i just got a 2008 sportster 1200 nightster and have deided to get rid of the sport bikes and get a harley well i just got it bought it used and runs great but i was out on it last night and got to a buddys house and went to start it and it just clicked 1 time and lost fire to everything so i turned the switch off and turned it back on and same thing well i got it home and decided to work on it and try to fix it now im getting fire in the acc position but not in the run position so i made a jumper wire from the run wire to the battery and it light everything up fuel pump primes and all but still just clicks any help would be appreciated thanks
Old Sep 26, 2010 | 03:36 AM
takamine4's Avatar
takamine4
sound like your starter relay (main relay) is dead. $20 and it should run
Old Sep 27, 2010 | 09:03 PM
TM82's Avatar
TM82
Stage II
no luck just got this bike rode it 10 miles and already messed up not looking good for harley
Old Sep 28, 2010 | 02:11 PM
95custmz's Avatar
95custmz
Put your battery on a load tester.Sometimes it will Show adequate voltage but when you go to start bike there is a drastic voltage drop. Also, check your sensors.I would start with the crank pos. sensor.
Old Sep 28, 2010 | 03:05 PM
LozoB's Avatar
LozoB
Check connection from battery at the starter. The same thing happened to me once. There was a little corrosion under the nut. Cleaned it and everything was good.
Old Sep 28, 2010 | 09:38 PM
rjg883c's Avatar
rjg883c
I had the same problem a few weeks ago. A starter relay was the suggestion of someone on the web. He told me to pull the relays and check how they look. I did that, they looked OK, so I just charged the battery and cleaned the cable ends to see what would happen.
It started OK a couple of times, then the problem reappeared. I pulled the battery and had it checked. The battery was bad, I got a new one and the problem seems to be solved.
Ron
king1pin1
2018+ Softail Models
20
Jul 5, 2019 01:00 PM
billyg1
Aug 23, 2015 08:13 AM
SomisMoto
Sep 24, 2014 08:45 PM
chiefeng
Sep 18, 2010 03:36 PM
2kanzam
Sep 2, 2010 03:42 PM
