Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I just found out that TTS has a new upgrade for the VTune process. This new version will extend the VTune all the way to 100% provided you collected enough good data to allow it to happen.
So you guys run the updater for this new package. I'm reading the info on it now. It seems to now require Windows XP or higher.
Ver. 161 is now released for Mastertune and on their updater service. It was pointed out that in the “Save and Restore” area was only allowing com ports 1 – 12 while in the programming area allowed 1- 16. So this version, as of today, had that fixed so you now get 1- 16 in all areas. In the new download you will so get a displacement calculator in the “Tools” drop down.
Just ordered my TTS ths week. While I now have a modest Stage 1 AC & SE slip-on's, next month going to cams, then BB, heads, etc.
Do you know if there is a TTS map for just the Stage 1 AC & SE Street Performance muffs?
Yes there is.
You don't need to wait on the CD. Simply go to their website an download their "updater" an run it. It will install all of their software and calibrations so you can get a head start.
