Tach Problem
Old Dec 29, 2010 | 07:36 AM
philinms's Avatar
philinms
Default Tach Problem
I have a new to me '04 Wide Glide with the handle bar bracket mounted Harley accessory tach. It appears to be reading about half of what I would expect it to: i.e. 1200RPM @ 60MPH in 5th. Any ideas?
Old Dec 29, 2010 | 08:05 AM
UltraNutZ's Avatar
UltraNutZ
can you trace the trigger wire from the tach and see where it's connected? I have a suspicion it might be connected somewhere at the speedo which is wrong. You have to purchase a pin for the ECM plug. Disconnect the ECM, put the pin with wire (you just purchased from HD) attached to pin #3 and run that to your tach trigger lead (usually run under the fuel tank)
Old Jan 12, 2011 | 02:59 PM
ruenjou's Avatar
ruenjou
5th Gear
Could it be possible that your tach is designed for dual-fire motor? Twincam motors are single fired and that may explain what you saw.
Sal C
Aug 28, 2020 10:51 PM
aharper
Dec 12, 2011 12:40 PM
GFredP
Oct 5, 2009 10:48 AM
DOGKILLR
Jun 22, 2008 04:43 PM
Hagar the Horrible
Nov 21, 2007 01:05 PM
