Fuse Block Mess - Need Help
Old Jan 3, 2011 | 08:59 PM
atrain68's Avatar
atrain68
An almost happy ending. I ordered the female terminal buss I mentioned above and that should be in next week. No big deal since it's not exactly riding season and I have other stuff going on.
I picked up a hobby knife, which is what I should have done in the first place. From there I was able to insert the knife in the front of the fuse block and lift up on a tang securing each terminal. The the larger gauge wires came right out the back with the terminal still intact and reusable. The smaller gauge wires were in there securely. I figured these wires might be fixed to the bridge itself.
I sprayed some WD-40 to clean up any corrosion on the front and back of the fuse block. I lifted each tang and gently tugged on the remaining two wires. At first nothing, but then both wires released with the remainder of the terminal buss attached. I clipped the wires off the bridge and now I'm ready to put everything back together.
Lessons learned from this dumbass mistake:
Each terminal buss has five fixed terminals for the smaller gauge wires. Larger gauge wires have a terminal crimped on so they can snap right into the back of the fuse box. For this fuse block the "J" column on the block is unused so when installing a new terminal buss, the furthest right terminal can be removed from the buss.
Had I done this correctly, I could have used my hobby knife to lift the tang on the orange/black radio wire, back it out of the fuse block, snip of the terminal, and then crimp my radio wire and amp switched power wire to a single replacement terminal. Snap it back in and project over.
I hope this post and confession of stupidity helps someone out in the future. I guess I can't have too much self pity. The mistake cost me less than $10.
Attached Thumbnails Fuse Block Mess - Need Help-fuse-buss-hdf1.jpg   Fuse Block Mess - Need Help-buss-removed-hdf.jpg   Fuse Block Mess - Need Help-buss-removed-on-table-hdf.jpg
Michael R Moore
Electrical/Lighting/Alarm
Jan 23, 2019 12:21 PM
KSully63
Mar 13, 2014 09:18 AM
iammulva
Jan 7, 2014 03:01 PM
blksoftail
Apr 20, 2013 09:45 PM
Cruiser 1970
Jan 17, 2008 07:10 PM
