Considering the 07's LEAN condition
Mind you I just make little changes in areas that dont seem right an go from there.
to get it perfect then Dyno time is needed.
Take Care,
Bill G
Let's explain some of the above terms used in this chart:
AIR FUEL RATIO this is the amount of air, by weight, that is used in relationship to the amount of fuel. We will call this AFR.
STOICIMETRIC a scientist's term for the theoretical perfect burn. All hydrocarbons(fuel) and all oxygen are consumed, leaving only carbon dioxide and water vapor. This is the target AFR that manufacturers use to pass emissions.
BEST MEAN LEAN TORQUE this is the AFR where an engine that is NOT under load, creates its best power with the least amount of fuel. This spot can be found by the old tried and true drop idle test on the low speed screw on a carburetor. Turning the mixture on a carburetor (or the green pot on a Fi2000) until you find the setting where the engine runs at its highest and smoothest idle. This also explains best fuel mileage because you are achieving the maximum horsepower that the engine can produce at cruise speed, allowing you to ride with the least amount of throttle opening
BEST MEAN TORQUE this is exactly what it says, with the engine under load, this is the AFR where it produces maximum torque or power.
CARBON MONOXIDE PERCENTAGE because CO is the direct by-product of any mixture richer than stoicimetric, and it increases almost linearly with that richness, it is the best gas of 5 gases on a EGA machine to watch when you are tuning for performance. Even cruise fuel requires a slightly richer AFR than 14.7 and power fuel even more.
AFR TEST EQUIPMENT it's not on the chart, but all this data doesn't mean much if you cant see it. There are two technologies currently being used for accurately seeing AFR.
1. 4 or 5 gas exhaust analyzers. These are the machines you see when you get your car smogged. The gases give a complete view of what is happening inside the combustion chamber. Oxygen gives a very accurate lean side of the fuel map, CO gives a very accurate view of the rich side of the map, Carbon dioxide (CO2) gives an accurate view of the completeness of the burn and Hydrocarbons (HC) give indications of incomplete burn, like fouled spark plugs, etc. All four gases combine to calculate the AFR.
2. Wide band oxygen sensors. They are very fast, easy to incorporate into computers and dynos because they create an electronic signal. But they are more accurate on the lean side of the AFR fuel curve.
What does all this mean? Simply, if you look at the chart, an engine wants a different AFR when it is cruising than when it is making power. That makes sense, when the engine isn't under a load, a leaner mixture can get the job done. And this fact is exactly what manufacturers use when they are tuning the AFR maps. They can tune the light load/cruise zone for best emissions and good fuel economy, but when the throttle gets cranked, and you demand power, the EFI map can jump into a much richer range and produce power. Engines that just stayed at 14.7 wouldn't have any acceleration and would overheat and detonate.
This is also how a conventional oxygen sensor works. Under light load it tunes the fuel map to 14.7 until the throttle is cranked and then the richer fuel in the map takes over.
Let's start applying this to the tuning of EFI:
1. Cruise, light load wants AFR of 14.0-14.2. or 2.5% - 3.0% CO
2. Power, high load wants an AFR of 12.8-13.2 or 6.0% to 7.0% CO
The only fuel demand we haven't covered is acceleration fuel. That is the fuel demand by the engine when it transitions between cruise and power. In carburetion, you see this as mechanical accelerator pumps, they know that for best response, you need to quickly introduce fuel to make that switch. EFI maps do use both throttle position sensors and manifold vacuum sensors to detect sudden changes and
