Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
so i put front and rear LED turn signals on my street bob, and now its all goofed up, they all work but only my rear right turnsig will blink when i hit the botton. i got a load equlizers and put that on, but it didnt do anything for me.....
You didn't say what equalizer you are using, but I use a Smart Equalizer by Biketronics. They have an instruction sheet that really should be followed. If you go to their website you can down load the whole instruction sheet, it may be useful even if your using a different brand. They also give instruction for clearing fault codes which I have copied here. It's worth a try.
Fault codes can be cleared using the turn-signal buttons on 03 and later bikes using the following procedure:
1. Set RUN/OFF switch to OFF.
2. Turn IGN switch ON-OFF-ON-OFF-ON.
3. Press left turn signal switch 2 times and release. Bike responds with 1, 2, or 3 flashes to indicate type of turn signal module.
4. Press right turn signal switch 1 time and release. Bike responds with 1 flash.
5. Press right turn signal switch 1 time and release. Bike responds with 2 flashes.
6. Press right turn signal switch 1 time and release. Bike responds with 3 flashes.
7. Press and holdleft turn signal switch until bike responds with 2 flashes.
8. Turn IGN switch off. Codes should now be clear. Š
