Need help after bonehead mistake
Old Feb 20, 2011 | 04:31 PM
gdaustin's Avatar
gdaustin
Default Need help after bonehead mistake
Well to make a long story short I was putting in the running\brake\turn signal conversion harness for the tour pack when I put the terminal pin connectors into the wrong holes in the new connector. Of course getting it out destroyed the one pin connector. Now I need a new pin connector for the one wire. Accoreding to the service manual they are Tyco 070 multilock unsealed connector pin terminal. Problem is where can one get one of those so I can fix the one wire then insert it into the connector and continue? The bad part was I read the instructions before doing it and it clearly states pin 2 unused, pine 3 violet. I would hate to have to buy the wjhole thing again. Thanks.
Old Feb 20, 2011 | 04:35 PM
ThunderBueller's Avatar
ThunderBueller
You can get them at the dealer.
Old Feb 20, 2011 | 05:18 PM
TFTCAR's Avatar
TFTCAR
Smile
If that doesn't work go to your local auto parts store, there are a number of companies that make electrical accessories, have a look through one of their catalogs and you will be able to find the terminal you are looking for. You may have to buy a pack of 10 but then you will have extras encase you do the same screw-up again.
soulpatch
Electrical/Lighting/Alarm
Jul 17, 2019 12:49 PM
aloxdaddy99
Sep 30, 2011 02:37 AM
DesertDyna
Jun 28, 2010 07:32 PM
riteway
Mar 18, 2009 12:48 PM
jrsmith_80
Apr 1, 2008 11:34 AM
