Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
This may be hard to diagnose without seeing the bike, but here it goes. I have a 1998 Heritage Softail with a new battery. I was out riding yesterday and everything seemed fine. Towards the middle of the ride, I turned the bike off to ask someone a question, the bike would not restart, I had to jump start it.
On my way home, the bike was backfiring, speedometer didn't work, lights dim, etc., then it stalled while I was driving it. I know its an electrical problem, but have no idea where to start to diagnose/repair. Any help would be appreciated.
probably should start with checking the ground wire first. Sounds like a loose ground or maybe corosion at a connection. Be sure to check the frame connection too.
Also check the crimps at both ends of the (+) and (-) battery cables where the terminal is attached to the wire of the cable. There is one at each end of each cable. I've seen a few of those come loose.
