Crank no Start
Old Apr 11, 2011 | 09:00 PM
gliden2005's Avatar
gliden2005
Stage III
Default Crank no Start
out riding and bike died but would not restart. Took off hose to fuel rail and put in a bottle and hit starter button and fuel came out like you are pouring it out of a gas can. fuel pump cycles when you turn it on. any thoughts?
Old Apr 11, 2011 | 11:41 PM
kkiley's Avatar
kkiley
Did you check your bike for codes?
Old Apr 11, 2011 | 11:44 PM
hucks 08's Avatar
hucks 08
im guessing crank sensor,
Old Apr 12, 2011 | 08:04 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
+1 what he said
Old Apr 12, 2011 | 09:39 AM
gomiller2's Avatar
gomiller2
did you check to see if your getting any spark at plugs if not could be crank position sencer very common problem that harley has never ben to fix good luck
Old Apr 27, 2011 | 07:39 PM
gliden2005's Avatar
gliden2005
Stage III
it was the fuel pressure check valve in side the tank, which is the coragated tube. It had a hole rub in it, which put the pressure in the tank not the fuel injectors.
Old Apr 27, 2011 | 08:48 PM
fairfax1000's Avatar
fairfax1000
Make sure you replace all the lines, use the crimping tool to ensure the clamps are tight. Be careful putting it back inside or you'll hear that funny sound of fuel splashing against the tank way too soon.
zschaeff205
Jul 14, 2016 10:41 AM
1911NT
Jul 9, 2016 04:30 PM
taizer
Jun 29, 2015 07:11 AM
Win_Brad
Jul 30, 2007 11:12 PM
irlm1
Jul 8, 2006 04:21 PM
